Sponsored by: Innova
Quick Sound Dampining Question
Old Jan 1, 2007 | 08:07 PM
B-rent's Avatar
B-rent
Default Quick Sound Dampining Question
I got Circuit City's Tsunami in my 98 Dodge Avenger back in hs about 3 years ago. Would that even be worth the trouble heating up, removing and applying to the vette? Im going to be putting a single P2 12 running off of a Pioneer 760W amp in the near future (had 2 p2's in the avenger). Just didnt know if its worth saving or not
Old Jan 1, 2007 | 09:07 PM
fej's Avatar
fej
Tsunami as in the "upgraded" option for the factory stereo? If that is what we are talking about it is not worth the effort bro, about .1% of all factory stereo systems produced in all cars would be worth the effort to install them in to another car, and I don't believe that is one of them.
Save for a couple of months, and pick up a new HU with the features that you desire + a front 6.5" component set for the front and don't look back. (probably need an amp to run the components however, might want to consider doing a 4 channel amp, 2 to the components and 2 bridged to the sub)
G'luck
Fej
Old Jan 1, 2007 | 09:31 PM
B-rent's Avatar
B-rent
No sorry, Tsunami was the name of there Dynamat type matierial that covered the trunk. It has the silver foil and a black tar type material that was heated a little and molded into the spare tire well, trunk floor, and under the rear dash.
Sorry I should have been more clear
Old Jan 1, 2007 | 10:16 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Massive amount of work for very little gain. It probably would not stick after all that effort anyway. Why bother?
Get a new sound deadning solution - just not Dynamat Extreme - get something cheaper. I like eDead (personal preference).
Old Jan 2, 2007 | 01:24 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
x1000000000000000
Old Jan 2, 2007 | 02:11 AM
B-rent's Avatar
B-rent
Sounds good, thanks guys. Now I just gotta figure out if I want to buy a box or build my own
To Quick Sound Dampining Question
