Amp mounting idea
Jan 3, 2007 | 09:45 AM
Amp mounting idea
I was on ICIX and saw the Project 350Z thread and thought this looked cool,
although seeing the daylight pictures, if I did this it would be without the fans on top..
OR should I just keep going and have it set-up to see the top of the amps
Jan 3, 2007 | 10:40 AM
Call me crazy, but I like seeing the amp's guts.
And I like the fans, too.
Jan 3, 2007 | 11:13 AM
I like it. Do you just cut a piece of plexi to act as the new top then? I guess it would have a hole in it too for the fan air flow.
Jan 3, 2007 | 12:18 PM
i like the amp gutts too, not sure i'm sold on the fans though.
Jan 3, 2007 | 12:21 PM
St. Jude Donor '06
i like it as well, but i would like to see thinner fans or even smaller ones.
Jan 3, 2007 | 01:01 PM
Quote:
Originally Posted by
JAMIROBri
Yes, but that is actually the bottom of the amp.. Also there is a hole cut for the fan. with these the fan is set as an exhaust fan.
I like it, I am on the fence about the fans as the fans in that set-up would make my hatch area useless above the amps.
Now, I could do a squirrel fan on one end of each amp..
Check out the night time Bling:
Jan 3, 2007 | 01:03 PM
lso my amps will be similar to the one on the right (closer in this pic)
Jan 3, 2007 | 01:54 PM
Cruise-In IX Veteran
Jan 3, 2007 | 02:01 PM
pentavolvo
Do It!!!
You still got a connection for some Plexiglass?
Jan 3, 2007 | 02:28 PM
i can make a phone call see if someone wants to make some disappear from work
Jan 3, 2007 | 02:59 PM
pentavolvo
LOL.. dimension's are the same as your Nine.1 (but X2 for 2 amps)
Although the tops of the eD amps look real nice too...
Jan 3, 2007 | 03:09 PM
St. Jude Donor '06
