Sponsored by: Innova
help with Navigation install in a 95
Old Jan 3, 2007 | 03:04 PM
ynk1121's Avatar
ynk1121
Default help with Navigation install in a 95
EDIT: Im all done. Pics are up in C4 Gen:
http://forums.corvetteforum.com/show....php?t=1592946
I'm in the middle of instaling a eclipse avn6600. Where do i connect the vss wire and reverse wire? those 2 wires are all i have left to do
Old Jan 3, 2007 | 03:09 PM
-=Jeff=-'s Avatar
-=Jeff=-
Auto or 6spd?
Auto you can get the reverse off the shifter harness..
VSS will be on the CCM (in front of the radio).
I don't have the pin #s at work.. do you have the Shop manual?
Old Jan 3, 2007 | 03:35 PM
ynk1121's Avatar
ynk1121
Originally Posted by -=Jeff=-
Auto or 6spd?
thanks. its an auto. nope no shop manual. i guess i'll call it a day. tomorrow is supposed to be nice anyway.
Old Jan 3, 2007 | 05:33 PM
ynk1121's Avatar
ynk1121
Originally Posted by Hooked on vettes
For reverse for an auto trans. on the Transmission Range switch there is a Pink wire which is 12 volts from Backup Fuse F28 15 amp. When the transmission is placed in reverse 12 volts goes thru the switch to a Light Green wire.
Verify 12 volts is what the unit is looking for when the trans. is placed in reverse.
If it is, tap into the Light Green wire.
The Light Green wire powers the two Backup lamps and the two Backup cornering lamps.
ok. hooked on vettes told me the reverse wire. that means all i need is the vss
Old Jan 8, 2007 | 04:02 PM
ynk1121's Avatar
ynk1121
Old Jan 8, 2007 | 04:14 PM
-=Jeff=-'s Avatar
-=Jeff=-
I will try to get the #s for you tonight.. Assuming I have time
Old Jan 8, 2007 | 04:29 PM
ynk1121's Avatar
ynk1121
Thanks but I got it finished. check out the link I posted. it has pics
To help with Navigation install in a 95
