Which C5 front & rear speakers??
Also any recommendations on where and what speaker wire to buy? Thanks in advance.
Chad
As far as wire, i would go with knukonceptz.com wiring. i've used several of their kits and rca's. i like them a lot and the prices are good.
you can buy a good 2way component system for $150 and ditching the rears would save you some money for wiring and for an amp for the fronts.
http://www.woofersetc.com/index.cfm?...date+Selection
i went with the cdt cl-61a's. im very happy with them.
depending on what speaker you go with will dictate what amp you choose.
if you are going unamped i'd look into some 6.5" coaxials maybe infinity, boston's, jl-audio, or polks. i dont have much experience with those so the best bet is to go to your local car stereo shop and have alisten to a few.
1) Is it possible to power the 12 sub and front speakers with the 500X 4way amp?
2) How much better do the component systems sound over the standards? Would I have any install problems- one vs. the other? Thanks Chad
Having dedicated drivers for the high, mid, and low range of frequencies will sound better, but only if you use the proper x-overs and amplification.
Looks like you have the amp and sub, so go ahead and invest on component speakers for the doors.
Don't worry, once you start, you'll never stop, no matter how good it sounds.
For the front components would I be better off just buy Audio Daves door speaker kit or can I work everything with the factory spots? Thanks
Alright guys I need some more detailed help. The following is what I have- now what else do I need to make this happen (along with someone with the know how
).Specs on the 12in sub I got from EG
P212D4
12" Punch P2 4-Ohm DVC Subwoofer
Impedance 4-Ohm x 2
Power Handling 250 RMS
500 Peak
Motor Size 60 oz. double stacked
Voice Coil Diameter 2" aluminum
Speaker Connector Dual 8 AWG compression
Mounting Depth 6.125"
Rec. Sealed Enclosure 0.85 cu. ft.
24.07 liters
Rec. Vented Enclosure 1.75 cu. ft.
49.56 liters
Tuning Frequency (vented) 37 Hz
Weight 12.9 Lbs.
(5.9 Kg.)
CDT CL-61A 6.5 2way component speakers (front doors)
CDT CL-5EX 5.25 Coaxial speakers for rear
Rockford Fosgate 500X 4 channel Amp
Sub thump 12 box
HUMOUNT KIT on order from Dave
Front door speaker mount kit on order from Dave
Wiring harness and Antenna adapter on order from Dave
Pioneer Avic (N3)
FATMAT & Crazy cowboy kit
Earthquake Amp kit & various speaker wire
Now what else do I need? Really would like to get by without having 2 amps - will this be possible with the help of the 50x4 HU? Also anyone any the Central TX area who would like to help install feel free to send me a PM.
Anyone else have any thoughts?
