Sponsored by: Innova
C5: '01 vert install
Old Jan 5, 2007 | 11:26 PM
GeorgeB's Avatar
GeorgeB
Default C5: '01 vert install
WOW, time flies. Finally started over Christmas break. Here is the old thread: http://forums.corvetteforum.com/show...ghlight=budget
Put in RAAMmat in strategic places:
Insulation kit went in:
Main power wire going in:
HU test fit:
Door speakers in work:
Old Jan 6, 2007 | 02:20 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
FYI the crossover wont work there on the drivers side it hits the little vent in the door... atleast it did on the last C5 i did
Old Jan 6, 2007 | 10:13 AM
GeorgeB's Avatar
GeorgeB
I thought it would clear since the xover fit behind the wires without pushing them out any and it looked like the vent went right against the wires. I have not tried to snap the door in place yet though. If it does not fit there, what about if I chisel out some white foam in the door panel?
Old Jan 6, 2007 | 01:54 PM
DPG's Avatar
DPG
St. Jude Donor '06
scott_fx cut into the styrofoam for some reason without incident. you'll be fine. cutting into that crap is ok too for the most part.
Old Feb 21, 2007 | 11:07 PM
GeorgeB's Avatar
GeorgeB
Default Update!
Finished her up and hit the road. The bottom line is I am very happy with the end result.
Here is the back finished - stealth:
Here is what lurks underneath:
I cut a hole in the cover so it would fit over the woofer:
This is the amp from the back:
AMp from the front:
Last but not least, the head unit:
I applaud NVTHIS for the sub box construction. It is nice and solid. The woofer is just a lowly MTX unit but it pretty much is exactly what I was looking for. The head unit works fine and has lots of adjustments. I just put the fronts on 6 dB/oct at 80 Hz and same with sub just for a quick setup. The amp is very clean. The CDTs are very nice with the silk tweets and the soundstage comes right up with the extra dash tweets. Dire Straights sounded awesome "Your latest trick", as did Ozzmosis "Perry Mason", Metallica has too much bass for my settings right now. I also played with the Boston Rally Collection and Sheffield Drive, lots of fun. I am getting the stupid bose insignia vibration though on certain freqs, gotta fix that. Also noticed quieter interior and cooler tunnel so the insulation and sound deadening work. I did not have a dB meter for this trip but it was noticeable for sure. For my little budget build it turned out great!!!
Old Feb 21, 2007 | 11:39 PM
DPG's Avatar
DPG
St. Jude Donor '06
very nice. i have the same components and love em for the price.
Old Feb 21, 2007 | 11:49 PM
pentavolvo's Avatar
pentavolvo
looks sweet and i bet you love that radio
Old Feb 21, 2007 | 11:50 PM
scott_fx's Avatar
scott_fx
very nice! that amp is my second favorite amp that i've ever owned! such agreat sounding piece. nice install too
To C5: '01 vert install
