Does radar detector make a difference?
Do the detectors on the market now actually make a difference or are they giving a false sense of security followed by a ticket?
The radar detectors of today don't false nearly as much as the ones from years ago.
I have a Valentine 1. Works great, but beware instant on. Always makes sure you're tailing a car up ahead with a good spread between you.
One thing you should know also: if you're going 15-20 mph over the limit and the guy lights you up with any kind of radar, you HAVE a ticket. You just can't jump off the accel pedal and onto the brakes and get the speed down fast enough. That's if you're the one being targeted.
BTW the newer radar guns can pick you, the speeder, out from a crowd.
Take it for what it's worth. All you read about is, "how the radar detector saved me". Well maybe if it was pointed at someone else and THEN you reacted. But if it's on you or if it's instant on, you're cooked.
My Escort is a good preventive tool, but nothing's gonna make you invisible and with instant-on, POP and laser . . .well, you've just gotta be really lucky.
Many departments have switched to lidar (laser), and a detector is essentially worthless against that. You need a jammer. Escort and Blinder have good ones. My ZR3 Shifters give me up to a quarter of a mile to slow down before the lidar can burn through the jamming. But the cop has to be in line of sight that long. If he's hiding around a blind curve and pops you at the last second, he can still get you before you can slow enough to avoid a ticket. (But you shouldn't be going that fast around a blind curve anyway.) Waiting to the last second is difficult with the lidar too because of the required aiming accuracy. Most cops will try to get you as early as they can while the angular rate is low, thus giving you the needed warning time to slow down before they can burn through the jamming.
Nothing, aside from a lightbar and a badge, will keep you from getting a ticket every time. But good radar detectors and laser jammers, coupled with alertness and situational awareness, will make your chances of avoiding a ticket much better.
The Escort 8500X50 has fewer false alarms than the Valentine 1. Since most departments have abandoned the old X band radars, turning off X band (mostly used by door openers and security systems today) will reduce your false alarm rate even more. If you have a long commute, as I do, you'll also quickly learn where the false alarms are located, and will come to expect them as a check on your detector's continued proper function. You'll also learn where the cops like to set up their ambushes, and drive through those areas with heightened alertness.
I credit the detector and jammers with helping me avoid the revenue enhancers at least 2 or 3 times a week (in common with most Atlantans, I routinely speed). Of course there's no magic bullet. I haven't had a speeding ticket in the 23 years I've been using countermeasures, from the early Fuzzbusters to the modern Escorts, but that doesn't mean a cop won't get lucky and get me tomorrow. The point is, though, he'll have to get lucky. All of the tricks to avoiding a ticket are second nature to me by now. Using a detector is only one part of that.
I've found that a good rule of thumb is; don't be the fastest or most conspicuous vehicle on the road. Try to imitate a fox and let the rabbit run out ahead.
I've found that a good rule of thumb is; don't be the fastest or most conspicuous vehicle on the road. Try to imitate a fox and let the rabbit run out ahead.[/]
Been using radar deletectors for a long time and been using Val 1's since Valentine first brought them out. The detectors have saved my wild speeding *** from tickets MANY, MANY times including a few instant on's (so long as your not way over the limit and quick of foot with the brake). They are best when running in traffic with the rabbits out ahead. When running solo on street and highways you must use your street/road smarts, be alert and eyes OPEN if your going over the limit. Of course, for the very few times those detectors didnt save me, it helps to have a FOP card as well
And always - ALWAYS have a rabbit
I have K-40 in the 300C and the ZR3/SR7 in the Vette, both have paid for themselves, but they are only part of the solution.
