Sponsored by: Innova
pin-out for remote hook-up
Old Jan 6, 2007 | 09:51 PM
IC6's Avatar
IC6
Default pin-out for remote hook-up
does anyone know which factory color pin-out (non-bose, c6) is the ignition power source, so i can tap in for my remote wire for my amp.
Old Jan 7, 2007 | 08:37 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
There's not a switched power wire in the radio harness. The radio is turned on & off by the car via the serial data bus (that's how RAP works) so the +12 you'd find in the harness is always hot.
I ran a wire down into the passenger footwell and tapped into a fuse there. I used the wiper circuit, works like a charm. You can either just put a wire on the fuse or grab an add-a-circuit at a parts store and it it in that way.
Old Jan 7, 2007 | 06:17 PM
IC6's Avatar
IC6
i tapped into the wiper circuit like you said, but the amp stays on. . is there another fuse that is switched power?
Old Jan 8, 2007 | 05:10 PM
IC6's Avatar
IC6
nobody
Old Jan 8, 2007 | 05:13 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
u sure u hooked it up right cause the whipers should shut off with the car meaning the amp will... otherwise get a voltmeter and start checkin other fuses
Old Jan 8, 2007 | 07:55 PM
IC6's Avatar
IC6
thanks.. thats what i'll do.. maybe i hooked it up wrong before.
Old Jan 8, 2007 | 07:58 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Sorry, didn't see your second post...
I'm sure I used wiper and it's not tied into RAP, shuts off soon as I press the ignition button. As suggested, double-check your wiring.
Old Jan 9, 2007 | 12:34 AM
hymnatr's Avatar
hymnatr
I used the wiper circuit just like komoman and it works perfect. Found the add-a-circuit at autozone.
Old Jan 9, 2007 | 04:37 PM
IC6's Avatar
IC6
i tapped into the wrong circuit, found the wiper fuse, works great... thanks again!
just need a c6 front or rear emblem to finish the look of my setup, came out really nice... other than ebay ($39 -- ) anyone know of a cheaper place?
pics to come...
Old Jan 9, 2007 | 04:50 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
pics to come...
Glad to hear it worked for ya.
Sorry, no source I know better for the emblem.
To pin-out for remote hook-up
