Sponsored by: Innova
Sirius FM Modulation Question....
Old Jan 12, 2007 | 03:44 PM
slayer6x6's Avatar
slayer6x6
Default Sirius FM Modulation Question....
I just bought the Sirius One kit for my C5, but the FM reception is poor. I tried changing to different radio stations but I'm getting a little fuzz. Is there any way to improve FM modulation, or is this just a characteristic of a cheap Sirius unit?
Old Jan 12, 2007 | 03:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
just about every FM modulator is poor. Its not neccesarily the brand, its just FM. Only way to get better quality is to hardwire
Old Jan 12, 2007 | 03:54 PM
scott_fx's Avatar
scott_fx
are you using an fm modulator or fm transmitter?
Old Jan 12, 2007 | 03:57 PM
slayer6x6's Avatar
slayer6x6
Hhmm, I guess it would be an FM Transmitter since its not hardwired to the antenna. I am using a factory radio, is there anything I can do here?
Old Jan 12, 2007 | 04:15 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
get a hardwired modulator then you will be golden
Old Jan 12, 2007 | 04:20 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Either that or one of the AUX solutions via the changer cable that's available for the C5, whatever's cheaper. Sat radio sound quality is so mediocre (and I'm being kind) that you really can't hear a difference between wired modulator and an AUX input.
Old Jan 12, 2007 | 05:34 PM
slayer6x6's Avatar
slayer6x6
Does anybody have a link to the AUX input cable. It sounds like that would be my best bet.
Does the Aux input cable require a module like the ipod adapters?
Old Jan 13, 2007 | 06:22 PM
slayer6x6's Avatar
slayer6x6
anyone?
Old Jan 13, 2007 | 07:16 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
You would need the PIE GM10-AUX along with the COR-HAR harness. For this to work you need to NOT have the CD changer. There is a link in the C5 FAQ that shows you how to build a switch and still use this if you do have the changer.
I've bought from this guy and gotten great service:
http://www.myradiostore.com/auxadapt.../gm10-aux.html
You may need to send him an e-mail about the COR-HAR that you need as well.
Here's the PIE application guide:
http://www.pie.net/images/appguide/appl_aux.pdf
Old Jan 14, 2007 | 02:29 PM
slayer6x6's Avatar
slayer6x6
Awesome! Thanks for the links
Old Jan 15, 2007 | 11:43 AM
JazyJeff13's Avatar
JazyJeff13
You will get rid of the static, it will not improve the sound quality though, you right on that one
To Sirius FM Modulation Question....
