Sponsored by: Innova
amps?????
Old Jan 16, 2007 | 09:27 PM
obi05rp's Avatar
obi05rp
Default amps?????
deciding on goin with either one 12 " memphis or two 10" memphis subs
question is what amp or rather power rating should i run with... the subs are 250 /500 max... should i go two amps or one 1000watt amp .. this stuff gets a little confusion.
Old Jan 16, 2007 | 09:34 PM
scott_fx's Avatar
scott_fx
what's your budget? and what voice coil configs are they available in? i'd definately stick with one amp, there is no need for two amps. which amp you choose can be affected by the above questions.
are you going to add components or just stick with stock speakers?
Old Jan 16, 2007 | 09:39 PM
obi05rp's Avatar
obi05rp
eventually i will be upgrading the whole system, as for now it will be just a in dash dvd and sub(s) and an amp... i believe both are dual voice coils.
Old Jan 16, 2007 | 09:51 PM
scott_fx's Avatar
scott_fx
a good amp to get may be the nine.2x
http://www.edesignaudio.com/edv2/adv...words=discount
that price is only good until feb 1st though
To amps?????
