Sponsored by: Innova
C2 Stereo Question-Need Amp?
Old Jan 20, 2007 | 11:19 AM
Paul L's Avatar
Paul L
Default C2 Stereo Question-Need Amp?
I currently have a Ken Harrison Enterprises model KHE-200 head unit in my 1967. It is rated at 50W x 4. I do not use the cassette player but rather an IPod Shuffle connected via the AUX jacks.
The head unit drives a Kenwood dual-cone dash speaker with each 4" one-way cone at 50W peak. Of course I do not get stereo separation but the sound is not bad.
In the spring I will be adding kick panel units to get four channels. The speakers are Kenwood 4" two-way (KFC-1060S) rated at 120W peak.
The question is: Will I need an amplifier when I add the kick panel speakers?
Old Jan 20, 2007 | 01:42 PM
DPG's Avatar
DPG
St. Jude Donor '06
you can always try it without the amp first. Those are all peak power ratings. not sure what the rms rates are.
Old Jan 20, 2007 | 02:21 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
with that low of power handling you will probally be fine
Old Jan 20, 2007 | 02:22 PM
Paul L's Avatar
Paul L
Here is the kick panel speaker: Rated power 20W. I would imagine the dash panel cones would be less.
http://img.photobucket.com/albums/v1...erwatts006.jpg
Old Jan 20, 2007 | 03:41 PM
pentavolvo's Avatar
pentavolvo
Thats really not alot of power at all what are the specs on your radio... with that said most aftermarket radios put out about 20 watts rms just to give you an idea so id assume yours is close. Are you going with those speakers for sure. Im only saying this because its not really gonna get that loud especially in a C2 which is a loud car id say
Old Jan 20, 2007 | 04:48 PM
scott_fx's Avatar
scott_fx
in short; will you need an amp, no. could you benefit from an amp, of course. the amp will give you more headroom meaning less distortion meaning more power for the speakers (they can handle more then the 20 wrms that they are spec'd at, but it has to be clean; aka undistorted, power)
Old Jan 20, 2007 | 05:32 PM
Paul L's Avatar
Paul L
Stock exhaust. Quiet as an Impala. Looks like I try the system as is in the spring. I don't like the thought of adding an amplifier to an electrical system with an original 37-amp alternator.
Old Jan 20, 2007 | 05:55 PM
pentavolvo's Avatar
pentavolvo
if you really arent looking for anything loud and you have a quiet car you should be fine
Old Jan 20, 2007 | 07:12 PM
Paul L's Avatar
Paul L
My thanks for the replies. No, I do not have sidepipes. I value tunes rather than engine noise. Perhaps in the minority of C2 owners!
To C2 Stereo Question-Need Amp?
