Sponsored by: Innova
anyone use poly or fiberfill
Old Jan 31, 2007 | 12:07 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default anyone use poly or fiberfill
I read an article on sound domain that polyfill or fiber fill (aka pillow stuffing) makes a sealed box sound like it's bigger. For us vette owners that's great news since space is at a premium. Has anyone actually tried this?
here is the refrence page:
http://forum.sounddomain.com/forum/u...=076651#000000
Old Jan 31, 2007 | 12:31 AM
VinceC5's Avatar
VinceC5
I have used it in every box that i've built. works great.
Old Jan 31, 2007 | 01:33 AM
DPG's Avatar
DPG
St. Jude Donor '06
im using it in my dual 10" box and it works. got the recommendation from fej a while back. i thought he was crazy for putting the crap in there. im like im not at build a bear but it does work
Old Jan 31, 2007 | 02:54 AM
fej's Avatar
fej
Yes it does work, to an extent. You CAN overfill a box and decrease its output. A rough guide is 1lb per 1cu^3. You can expect a max gain of "size" to the woofer of about 30% or so. So you can trick a woofer in a 1 cube box into thinking it is in a 1.3 cube box.
I would personally start with about 12oz in a corvette box, provided you have a baseline without it (meaning same tune, crossover point, same gains, same track) and see if it changes anything, if it gets a bit better and you are happy with it, leave it alone unless you want to play some more. I personally cannot see a vette box needing more than 1lb of the polyfill myself unless it is multiple woofer, or a large volcano type enclosure of some sort.
Maybe some of the box builders can chime in, I only speak from my experience. There is a chart somewhere online I will see if I can track it down.
Fej
Old Jan 31, 2007 | 09:18 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
the chart i found on my referance page suggests about 1.5 1.75 lb/sq ft. i'm going to try it out and see.
Old Jan 31, 2007 | 09:29 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Found some laying around at the shop. Tried it out and i didn't think the setup could have been improved, but it sounded noticably better...and that's before advanced amp tuning.
Old Feb 3, 2007 | 10:46 AM
srosa75's Avatar
srosa75
Does anybody use it on non-woofer speakers such as rear co-axial speakers in boxes?
Old Feb 4, 2007 | 12:41 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
i'm entertaining this thought but with a sealed tube instead of a box.
Old Feb 7, 2007 | 06:08 PM
vetterlatethannever's Avatar
vetterlatethannever
I have it behind my 8's in the doors, they are in a sealed enclosure and I am hoping to keep down mid range resonance with it.
To anyone use poly or fiberfill
