Sponsored by: Innova
head unit help pleeze
Old Feb 3, 2007 | 11:12 AM
zardoz7's Avatar
zardoz7
Cruising
Default head unit help pleeze
I'm in the process of installing a powered subwoofer in my C6. I disconnected the radio/CD unit (Bose) to add an adaptor cable (PAC ADD GM24). After running all the wires I but before hooking up the subwoofer, I reconnected the battery and attempted to play a CD to get a base-line for a "before" and "after" comparison with the subwoofer. When I tried to turn on the head unit, nothing happened.
So I backtracked, removing the adaptor cable between the head unit and factory cable, and reconnecting the factory cable....... and still nothing.
Is there some sort of anti-theft protection that disables the radio/CD once it's been disconnected? Any ideas?
Old Feb 3, 2007 | 12:16 PM
DPG's Avatar
DPG
St. Jude Donor '06
i dont know a whole lot for the c6, but have you checked fuses for the radio. maybe those blew.
Old Feb 8, 2007 | 06:16 PM
eesz06's Avatar
eesz06
3rd Gear
I have the same problem I am trying to find out how to hook a head unit up to the factory stereo. If I find information out Ill try to let you know but if you find info please do the same. thanks
Old Feb 9, 2007 | 09:32 AM
DPG's Avatar
DPG
St. Jude Donor '06
ttt
Old Feb 9, 2007 | 03:41 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I have disconnected and reconnected my head unit more times than I care to remember at this point and not had that problem, so there's no anti-theft feature like that. So I would do the basic troubleshooting as recommended by DPG, make sure your fuses are OK.
To replace the factory head unti you need a couple of modules to maintain chimes and send the signals the factory amp will require to turn on, etc. There are a few options, but here's a link to Peripheral's application guide:
http://www.peripheralelectronics.com...DATABUS2-2.pdf
To head unit help pleeze
