Sponsored by: Innova
C5 Coupe Rear Ground locations
Old Feb 19, 2007 | 02:01 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default C5 Coupe Rear Ground locations
Anyone have a pic of the screw/bolt that holds the rear middle compartment to the frame for some amp grounds.
Thanks.
Old Feb 19, 2007 | 04:54 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
unless you want to drill a hole through the floor, the best ground i've heard of is the seat bolt
Old Feb 19, 2007 | 04:59 PM
screw991le's Avatar
screw991le
Ok, thanks.
I have seen some posts where the seat post does not work.
Old Feb 19, 2007 | 05:38 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I think this may be because of how the frame is situated. I believe that only the outer seat bolts are connected to the frame (sombody please correct me if i'm wrong)
Old Feb 19, 2007 | 05:40 PM
Darion's Avatar
Darion
I used the passenger side seat bolt closest to the tunnel, rear most bolt. Ground is good, no noise. That bolt seems to be painted or coated with something so a good cleaning with a wire brush to bare metal was all it took.
JMHO,
Darion
Old Feb 19, 2007 | 05:46 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
If used both the outer and inner rear seat bolts never a problem, just make sure u tighten that sucker down when you put the seat back in
Old Feb 19, 2007 | 05:48 PM
screw991le's Avatar
screw991le
Ok, so brush off the paint and tighten it down. What about near the rear of the hatch. I might have to put an amp there. Are there any ground locations close to that area?
Old Feb 19, 2007 | 06:02 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I have a multiple amp setup with the sub amp mounted on the rear. I'm still using the seat bolt for mine (along with + and - distribution blocks).
Old Feb 19, 2007 | 09:15 PM
Darion's Avatar
Darion
As TheRadioFlyer said, both amps to one ground point should not be a problem and you can use a distribution block as stated. If you really want to do seperate points I do remember reading that you can pass through the rear of the hatch, the area behind the taillamps, and ground directly to the frame. I did a search but could not find the thread so maybe someone will chime in on that. That being said I would just go with one point and call it a day.
Darion
Old Feb 19, 2007 | 09:20 PM
DPG's Avatar
DPG
St. Jude Donor '06
you can ground in the back, but you have to drill. Pull the pass tail lights out and you'll see whats back there and see what you can use. there are some people who have used the rear.
Old Feb 20, 2007 | 07:44 AM
litnrod's Avatar
litnrod
Default Me too.
Two amp setup, rear seat bolt close to the tunnel. Big wire. no noise
To C5 Coupe Rear Ground locations
