Sponsored by: Innova
Head Unit Goes No Where... :(
Old Feb 20, 2007 | 01:21 AM
Ishams00vette's Avatar
Ishams00vette
Default Head Unit Goes No Where... :(
I started installing my new Premier 780 tonight. Got the entire dash apart...... pluged the new headunit in... BAM!!! nothing... i was so pissed. Taking the dash on these cars ISNTT alot of fun... but maybe thats just me..
Old Feb 20, 2007 | 01:51 AM
scott_fx's Avatar
scott_fx
where are you getting your ign/acc lead from?
Old Feb 20, 2007 | 01:53 AM
Ishams00vette
From the GM adapter, from the stock adapter. Just spliced em together.
Old Feb 20, 2007 | 01:57 AM
scott_fx's Avatar
scott_fx
thats why your head unit isn't working. check the faq to find out how to get a working acc lead
Old Feb 20, 2007 | 02:00 AM
Ishams00vette
I didnt see a FAQ. Did I do something crazy wrong or what?
Old Feb 20, 2007 | 02:03 AM
scott_fx's Avatar
scott_fx
nope, just a common mistake.
http://forums.corvetteforum.com/show....php?t=1117959
How do I get the acc power for my h/u?
if you look in the passenger footwell, pull out the cover and look in the top left corner. There will be a small plug with three wires (orange, yellow, & black) that are just taped up. Check out this schematic to see which fuses they use, but the yellow wire is the +12V switched, and that I am sure of.
or you can use fuse 22
Old Feb 20, 2007 | 02:06 AM
Ishams00vette
Thanks Scott. Appreciate the help as usual! I will have to try it tomorrow!!
Old Feb 20, 2007 | 02:09 AM
scott_fx's Avatar
scott_fx
you're welcome, good luck.. you're almost done
Old Feb 20, 2007 | 11:45 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
yeah its a common mishap, otherwise you can get at the ignition switch, its a brown wire like the furthest one forward, either spot will do it for you, then bam music. Test it before you put it all back together
Old Feb 20, 2007 | 11:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
dash is easy to take apart, a pain the first time you do it, but after that, you'll have it apart in 5 min
To Head Unit Goes No Where... :(
