Sponsored by: Innova
Speaker Clearance in C6
Old Feb 22, 2007 | 09:33 AM
Fcal's Avatar
Fcal
Default Speaker Clearance in C6
In the planning phase of redoing my stereo. Just wondering, what kind of room do I have for window clearance in the front doors of a C6? I'm looking to go with components and some of the mid/bass drivers look pretty deep. Was planning on using Kokomans cnc mounts.
Old Feb 22, 2007 | 10:08 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
If memory serves (questionable!) you have about 4" and maybe closer to 4.5". To give you an example, I know folks have mounted the Focal K2P's in that door, and the mounting depth of the midbass on that is 77mm (3.03"). It's a pretty hefty driver so you're probably good.
And thanks for considering my plates.
Old Feb 23, 2007 | 01:01 AM
cleaner145's Avatar
cleaner145
Just started the install on my C6 and they are perfect.
Old Feb 23, 2007 | 10:48 AM
Steve Germany's Avatar
Steve Germany
I have a set of DLS Reference (big magnets 4in) mounted with Dan's plates and they are bottom side mounted (not set into the plates) which increases the mounting depth. The passanger side had a clearance problem so I simply rotated the plate (since Dan optomized the speaker hole location to the door pannel hole). In this location depth is not a problem the magnet width is.
Great plates TheKomoman!
Old Feb 23, 2007 | 10:50 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Thanks for the kind words guys.
Keep in mind that I do have blanks available and you can cut your own hole(s) for position & size.
To Speaker Clearance in C6
