ok, seems that i can't find radioflyers pics of the foam stuff.
DPG, actually the Koolmat is pretty expensive. The fron kit cost me about $380. I do note on there website they now have a kit for the back but it is $459. How does this compare with the other products in cost. Also noticed they have a kit for the C5 now. Would love to take a look at that other product if you find the link/thread.
Jesus, Radio Flyer it is quite clear you have forgotten more about sound deadening, etc. than I am ever going to know. Great info. Let me elaborate on my setup a little more to make sure I understand your recommendations. The rear area of a c3 is much like the picture of your c5 except the bottom is flat. There is a vertical wall at the very back though, like yours. I have dynamatted this area entirely already, but if I understand you correctly, you would advocate putting these other products on the these areas, right? The mufller setup I have exits at the rear of the car. It is 3" with flowmaster delta flows. The mufflers are tilted at about a 45 degree angle under the very back of the car and tucked up underneath. The gas tank is right above them and behind them and the compartment we are talking about is behind the gas tank.
Keep in mind I am not familiar with the products you are talking about. Do they spray on, are they self adhesive sheet type. Please elaborate. Also is there something I should spray above and around the fiberglass shell over the mufflers. Thanks again.
your mufflers are at the perfect angle to project sound directly into the car. I used to have similar mufflers on my truck (2 SI/SI Flowmasters in 2.5") but they were mounted under the bed and the silverado had a good deal of stock insulation.
I reccomend Second Skin's overkill pro foam on top of the dynamat. Use a spray on adhesive ("misty" upolstry adhesive a good glue) to attach the foam to the dynamat.
