Sponsored by: Innova
How hard is it?
Old Feb 23, 2007 | 08:16 PM
grunz95's Avatar
grunz95
Default How hard is it?
I just purchased a 12 disc changer from a forum member, how hard is it to run the wiring harness from the changer to the fuse panel on the passenger side kick panel? Any help will be greatly appreciated.
Gary
Old Feb 23, 2007 | 08:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is very easy, Just remove the passanger kick panel and the plugs are right there. Then just run the wire down along the door sill, under the back near the speakers and into the center compartment. Do you have the mounting plate and brackets?
Old Feb 25, 2007 | 12:21 PM
grunz95's Avatar
grunz95
I don't have the unit yet, but the member said that the brackets are coming with it. I don't understand "to the center compartment". My coupe has the center compartment in the rear where the unit is mounted. At the kick panel what is the plug listed as?
Thanks, Gary
Old Feb 25, 2007 | 02:01 PM
screw991le's Avatar
screw991le
Picture is a tad large but here it is. Go to the right of the picture, they have red arrows.
To How hard is it?
