Sponsored by: Innova
Aftermarket amplifier "whine"
Old Feb 27, 2007 | 07:42 PM
1990dtgL98's Avatar
1990dtgL98
St. Jude Donor '10-'11-'12-'13-'14
Default Aftermarket amplifier "whine"
After re-doing my soundsystem, my speakers emit a "whine" that seems to vary with engine speed. I have the seperate subwoofer amplifier power wire running behind the distributor (1990 L98) but the speaker amp that emits the whine has the power wire from the battery straight back.
It also gets feedback from the 10-disk CD changer... while the car is on or off.
Is the amp shot? Or could it be a ground/power/interference problem? Any help would be appreciated.
Old Feb 27, 2007 | 08:01 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Most often it's a ground issue. I had this problem in my C6. I moved the factory head ground wire to my ground for my amp and it solved the problem.
Old Feb 28, 2007 | 01:11 AM
1990dtgL98's Avatar
1990dtgL98
Your saying the ground is a head unit ground problem?
Old Feb 28, 2007 | 01:18 AM
BlackMark's Avatar
BlackMark
Komoman,is this a common problem with aftermarket HU's?Would it be best as a general rule to ground the head unit at the grounding point for the amp to start with?
Old Feb 28, 2007 | 02:05 AM
fej's Avatar
fej
It can cause issues yes. I rank it below making sure you 1st have a good solid ground connection with proper gauge wire to begin with, followed by making sure that your signal wires (rca's mainly) are not being crossed or closely paralleled by your power wires. Hell I ran into a tiny bit of whine in my own car and had to move an RCA (quality piece) approximately 3" to get rid of it
Good solid ground connection meaning bare metal and tight to the frame, or back to the battery if you so choose. Loops can originate from the HU, but is more common with lower grade HU's that the "name brand" models.
G'luck
Fej
Old Feb 28, 2007 | 08:22 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
While as fej describes the problem CAN sometimes be in the equipment itself that is not what I was suggesting. The problem most often is that the 2 pieces of equipment involved (head unit and amp) are grounded at separate points. Since they are electrically connected via the RCA's (even though at low voltage) but grounded in separate places this creates the possibility of the good ol' ground loop. This manifests as noise, most often alternator whine (varying with RPM) as seems to be the case here.
Always start with the simple, so the first thing to do is use a common ground. This solves the vast majority of ground loop problems. On the assumption you have a solid ground for your amp (also as fej describes) then the best thing to do is to move the head unit's ground to the amp's ground point. On my C6 I have the factory head with an aftermarket amp and this resulted in a ground loop. I identified the ground wire in the radio's wiring harness using the service manual, clipped it and butt-connected a new wire on the side leading out of the radio, running it to my ground point for my amp. Problem was gone.
To Aftermarket amplifier "whine"
