the fan controller could use the 5v to slow down the fans. if you actually do need the 5v you can get that from a simple voltage regulator and capacitor. it's a very novice regulated power supply that you can solder up in a couple minutes
www.xoxide.com sells 12volt fans of varying sizes. i used 4 of their 70mm fans in my amp rack. the amperage draw is so low that they can be run off the amp's turn on lead wire with no problems.
well I tried a 12 volt power supply last night and I cant get it to work.
I tried the 12v with a half dead 9v on the other 2 terminals for the 5v and still nothing...
checked it in the computer again and it still works. I dont know...
