C4 1992 convertible Install Questions
I'm planning a aftermarket stereo install in my C4 'vert but need to check a couple of things, thanks in advance for your help.
1. If I rip out the stock Bose 'gold' system, I heard that I risk getting some trouble codes - is this true?
2. Is there an adapter I can buy that allows me to install a standard Alpine head unit (electrical and structural)?
3. I wish to put in a 6-point roll cage, which probably means I cannot use the front speakers locations. Has anyone installed a rear-only speaker system; or used alternative locations for front speakers?
Thanks,
Andy.
Quote:
The SYS flashing indicates the CCM has detected a fault in one of the electrical circuits. The one you have sounds like it is caused by the difference in the resistance in the dimmer circuit. Here is the tech bulletin for it: http://www.corvetteforum.net/c4/dave8476/index4.shtml, but this is more of a laymans version of what you'll need to do.
If "SYS" is displayed in the LCD section of the instrument panel cluster after the customer installs a new stereo, he will need to do the following:
1. Buy (2) 1 kilo-ohm 1/2 Watt resistors. [Radio Shack part # 271-023. They sell them as a 2-pack for 29 cents.]
2. Disconnect the negative battery cable.
3. Remove the receiver.
4. Connect one end of both resistors to ignition power. (Yellow wire in the car.)
5. Connect the other end of one resistor to the purple/white wire in the car.
6. Connect the other end of the second resistor to the grey/black wire in the car.
7. Cover all connections and completely cover the resistors.
8. Reconnect the negative battery cable.
Try Metra online:
http://www.metraonline.com/product_l...vette&type=ALL
Part number 99-3051 is a radio mount. I suspect they sell the electronic adapter too, I'm going to give them a call.
Try Metra online:
Also there is room the doors, but it will be custom work to get them mounted there
