Sponsored by: Innova
Crossover question
Old Mar 9, 2007 | 11:37 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Crossover question
I have a set of Infinity 6010cs. It has one extra screw on the Crossover marked -3db. What is that for? The manual says nothing.
Old Mar 9, 2007 | 11:41 PM
Kale's Avatar
Kale
usually there is a switch to mellow out the tweeter... A screw or a little ****?
Old Mar 10, 2007 | 12:15 AM
screw991le's Avatar
screw991le
It is a screw terminal for wire, just one marked -3db
Old Mar 10, 2007 | 12:28 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
u can either connect the positive lead of the tweeter to the tweet positive or the -3db it pulls down the level of the tweeter making it less harsh. Just put it at the -3db now and save yourself the hassle of messing with it later.
Old Mar 10, 2007 | 05:40 AM
VenkmanP's Avatar
VenkmanP
It's on p. 4 of the instructions, in the section on connecting the wires to the crossover.
Old Mar 10, 2007 | 07:36 AM
screw991le's Avatar
screw991le
I see that, but it does not say what it does. It just tells you what the screw is, that is why I asked what it does as far as sound quality
Old Mar 10, 2007 | 08:05 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
It depends on the position you mount the tweeter. Most of the time time in these small cabins you're better off using it as the tweeters will be relatively close to your ears. Pulling them down 3db is a good idea. My Focal components in my C6 have -3 and -6 on the Xover and I'm going to have to pull the door panel off to go to -6 on the front tweets. They're at -3 now and it's just too much.
Old Mar 10, 2007 | 08:46 AM
screw991le's Avatar
screw991le
Thanks for the advise. I mounted the tweets right above the mid, in the center of the panel. So the -3db looks like a good idea. Thanks
Old Mar 10, 2007 | 09:24 AM
VenkmanP's Avatar
VenkmanP
Which part of "To reduce tweeter output level, connect the positive (+) tweeter wire to the -3dB terminal" (p4, 6010cs manual) do you fail to understand?
Old Mar 10, 2007 | 12:38 PM
scott_fx's Avatar
scott_fx
someone woke up on the wrong side of the bed today
Old Mar 10, 2007 | 09:13 PM
screw991le's Avatar
screw991le
Thats ok Scott. If someone could read, I asked in a later post about sound quality, not what it does.
To Crossover question
