Sponsored by: Innova
Removing Rear Speaker Grills
Old Mar 25, 2007 | 10:12 AM
604_c5's Avatar
604_c5
Default Removing Rear Speaker Grills
Hey guys, I'm just wondering is there a way to remove the rear speaker grills without taking the plastic pieces apart? I have 2000 convertible, so i should have the 5.25" rear speakers
Old Mar 25, 2007 | 10:35 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes, take a small flat head screwdriver. Place it right in the top center of the grill. Slightly push down and out toward the center of the car, the grill will come loose off the top. Then just pull the grill stright up. It has 2 tabs on the bottom and one on the top.
Old Mar 25, 2007 | 06:57 PM
604_c5's Avatar
604_c5
I tried doing that, but seems like the grills are bending outta shape are the grills set up the same in the coupe & in the vert?
Old Apr 8, 2007 | 08:16 AM
604_c5's Avatar
604_c5
Old Apr 9, 2007 | 09:06 AM
3rd Childhood's Avatar
3rd Childhood
I just removed mine yesterday (2000 coupe) using the method described by Screw991le. One side popped right out. The other was a little stuck but came out with slight persuasion.
Old Apr 9, 2007 | 11:09 AM
screw991le's Avatar
screw991le
After looking around a little, I see that the verts cannot be removed from the outside. From what I see on some older posts.
To Removing Rear Speaker Grills
