Sponsored by: Innova
sven2 +svhgm4
Old Mar 25, 2007 | 12:37 PM
mufasanubis's Avatar
mufasanubis
Navigator
Default sven2 +svhgm4
Hello all, I have seen this discussed before, but I am still having problems hooking this up correctly. I am installing a new HU in a 2001 ZO6 and want to keep the bose speakers.
First question, does the sven2 and the svhgm4 tie in together, or do they work seperatly from each other?
Second question, I have the svhgm4 plugged into the sven2, and i am missing the 4 pin plug that ties into the factory harness.
Third question, when i had it all hooked up the subs weren't working I had no bass, but when I put the oem bose back in and didn't hook up that 4 pin wire harness I had all bass like if the other speakers weren't working?
These schematics are what I have. The svhgm4 don't have the harness for C3.
C1,C2, and C4 is hooked up.Do I need to jump a wire for the amps or something? Do I need the C3 plug?
Sorry such a long post and thanks in advance for the help.
Old Mar 25, 2007 | 02:11 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Have you considered getting the PAC adapter instead of having 2 other adapters. Just a thought.
Old Mar 25, 2007 | 03:03 PM
mufasanubis
Navigator
Thanks for the reply, but I have what I have and was hoping to be able to use them.
Old Mar 25, 2007 | 06:07 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
try to get in touch with dave at corvettecaraudio.com hes very helpful and he knows peripheral stuff in and out
To sven2 +svhgm4
