Sponsored by: Innova
amplifier locations...where to mount
Old Mar 26, 2007 | 07:40 PM
ctrain22's Avatar
ctrain22
Default amplifier locations...where to mount
Where is the best place to mount an amplifier? Amp I am going to use is about 18"x10"x3". Any creative ideas?
Old Mar 26, 2007 | 08:21 PM
OzzyTom's Avatar
OzzyTom
I bought a sheet of MDF (customwood) 1500x600x12 mm
I also had a sheet of cardboard, that I cut to fit in the rear section of my convertible 68. I positioned it so that it was at a slight rake, with the top edge against the rear section, just below the vent ducts.
I cut the cardboard so that it was a good tight fit around the wheel arches, and shaped to clear the convertible lid cover hinge mounts.
I used the cardboard as a template to cut the MDF. Then I cut out the holes for a pair of 3 way jbl speakers (rated at 120w rms).
I covered the MDF with black loop pile carpet, similar to the original.
I mounted a Sony stereo amp onto the inside edge of the MDF board.
Totally hidden. I then fitted the speakers and secured the panel using two angle brackets on either side and a third in the middle at the top edge see photo.... I haven't painted the bracket yet, but it's a neat tidy look, and I haven't lost too much space at all...
Sounds much better now... I can actually hear the music over the exhaust.
cheers
tom
Old Mar 26, 2007 | 08:50 PM
Durango_Boy's Avatar
Durango_Boy
I put mine on the back wall too. I used a sheet of MDF, cut it to size, and anchored it to the back wall with six bolts. There was plenty of room between that wall and the tank.
I then mounted the amps to the board. Easy.
Old Mar 27, 2007 | 12:58 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I need to get around to making that board for my car...
To amplifier locations...where to mount
