Sponsored by: Innova
DIY Sub box question..
Old Mar 29, 2007 | 10:20 AM
bbentley40's Avatar
bbentley40
Default DIY Sub box question..
Hey all.. I found this link for a DIY sub box in the FAQ:
http://home.comcast.net/~abbogus/Sub...sure_Vette.doc
I am getting ready to start building the box and got to thinking.. it doesnt say it is a stealth box. Has anyone built a box using these instructions and if so is it for a stealth box or a flush mount?
I figure if the directions are flush mount I can just modify the measurements some, but I am building the box at a different location than the car (friend has the woodworking tools) so it is hard to do quick test fits as the box is built.
If anyone can verify this as stealth or flush it would be very appreciated. Also, if you used these directions and have any pointers or tips that would be great too!
Old Mar 29, 2007 | 10:35 AM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
I'm thinking that is a flush mount box. The height of stealth boxes should be around the 7 1/4" - 7 1/2" range.
Old Mar 29, 2007 | 11:39 AM
robvuk's Avatar
robvuk
Ok, bring me up to speed here. What's a stealth box?
Old Mar 29, 2007 | 11:46 AM
NVTHIS's Avatar
NVTHIS
A stealth box allows you to place the factory center compartment cover back over the box, whereas the flush box sits flush with the flooring and will not allow the use of the factory cover.
Old Mar 29, 2007 | 02:01 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
This is a stealth box, it hides away well under the stock cover. NVTHIS made it.
Old Mar 29, 2007 | 02:27 PM
bbentley40's Avatar
bbentley40
That is kinda what I was thinking too, but I couldnt remember what I measured it at a while back. So no one knows for sure? I guess I will just have to measure it again tonight.
Old Mar 29, 2007 | 02:58 PM
NVTHIS's Avatar
NVTHIS
I can let you know here in a second.
Old Mar 29, 2007 | 02:59 PM
robvuk's Avatar
robvuk
Clever, those Japanese.
Thanks guys
Old Mar 29, 2007 | 04:17 PM
Duramax Dave's Avatar
Duramax Dave
Those are the plans that I used when I made my box. While I never actually tried fitting my cover over it, I would say it is the stealth box. There was one area that looked like the cover would barely fit (towards the front of the car) but overall that box will fit below the cover.
I have mine sitting in my garage. I sold my Vette last fall and so the box just sits there. Hope this info helps.
Old Mar 29, 2007 | 05:37 PM
01rc51's Avatar
01rc51
the cover will not fit, I have made 2 of these boxes
Old Mar 29, 2007 | 08:18 PM
screw991le's Avatar
screw991le
Which boxes?
Old Mar 30, 2007 | 10:10 PM
01rc51's Avatar
01rc51
the one in the FAQ
Old Mar 30, 2007 | 10:13 PM
NVTHIS's Avatar
NVTHIS
Lol! I guess my seconds turned into days,lol. 7 1/4" is the height of my stealth boxes.
Old Apr 2, 2007 | 03:53 PM
los7883's Avatar
los7883
When i did mine in my old C5 I didn't think there was enough room to put a box in the back so i just hacked away at the cover and mounted it on there...it worked somewhat, the speaker was too heavy and would cause it to bow so i got some 3/4" MDF and cut it to the same size as the cover, then took the mounting tabs and transferred them over to the MDF cover and carpeted the whole thing. I had to recess the mounting tabs as the orignal cover was thinner than the MDF, here are pics of it...again there was no box under this, just an empty well.
From the front looking back
From the side
From the top
Old Apr 6, 2007 | 09:31 PM
Brad@RevXtremeAutoSports's Avatar
A non stealth box.
To DIY Sub box question..
