Sponsored by: Innova
C4 Aftermarket Atenna Question
Old Mar 29, 2007 | 08:52 PM
fsmo's Avatar
fsmo
Cruising
Default C4 Aftermarket Atenna Question
Ok,
I have searched the forums and the web, so please do not refer me to the sticky C4 because I cannot find the answer for my situation.
I have an AVIC-D1 installed and all of the Bose equipment removed. Everything works except the antenna. I can hot wire it with another battery to go up in down, so I know it works.
The white unit ( not sure what it is) by the relay was corroded back by the antenna, so it is not in the loop. I would like to either have the antenna go up activated by the radio or manually, which ever is possible. Of course I have the three leads coming from the antenna - Any ideas how to hooked this up. Since all of the Bose hardware is removed, I am not sure the pink wires would function in the raising/lowering of the antenna. Much appreciated.
Old Mar 29, 2007 | 09:10 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
at the antenna i would ground the one wire run the other to a hot source then the switching wire run to the radio antenna turn on. Let me know what colors you have and i can tell you what is waht
Old Mar 29, 2007 | 09:15 PM
fsmo's Avatar
fsmo
Cruising
The Colors of the wires coming from the Antenna are white, green and gray.
To C4 Aftermarket Atenna Question
