??? about relocating hvac control unit
Be careful. I think the unit might come out far enough to hit the shifter.
Let us know how it comes out.
I have six speed though. I don't want a double din as I want to keep my lower compartment that houses cigarette lighter area for when I go with power adder and need to add in some extra's.
Thats exactly what I needed to see. Looks good, can you leave the screen up when the car is off? Not too sure I like it with the screen retracted, but versus having to do the cutting of the mount and the bezel mod, I think I could learn to (like it just fine).
Edit : well I guess either you are in fact Da Man, or you have Da Man taking pictures for you, or......you have unusualy hairy legs for a woman....but thanks just the same.
Da Man works fine
But I do likes Da Woman
Yes you can program the unit to stay open..just keep the head unit as high as possible in the opening so it will clear the shifter..
Steve
The problem arises due to the fact that I'm relocating the Heat/AC down to where the ashtray is and installing the flip screen in the center spot (basicaly a single din opening). But . . .any of the dash kits that say they are for a C5 corvette are made to fit a din and a half opening :-/ . Makes it tedious to locate a kit that fits the width but is only single din.
Oh well, all done now. Wound up talking to an installer while I was looking at metra kits, he had a surround that we made work
Pulled the Heat/AC controller, opened it up and soldered the resistors.....poof !....no more dim temp display
Everything is all worked out as far as mounting and trim for the center console. And I decided I'm mounting the computer in the rear over the right wheel well (not gonna work out behind the passenger seat, it's only about 3 1/2 inches deep, but thats a little too much to take off the seat adjustment)
Now I just have to run forty-seven thousand miles of wire
(VGA, USB, GPS, XM, power).Ill post something up when its done.
