Sponsored by: Innova
subwoofer confusion
Old Apr 8, 2007 | 12:35 AM
gator79's Avatar
gator79
Default subwoofer confusion
I purchased a Kicker CVR 10 and have a question on hooking it up. it has dual 2 ohm voice coils. with a 2 chanel amp can you just hook one chanel to each coil? the instructions that came with it show it wired either parallel (this would give me 1 ohm load) or series (this would give me 4 ohms load) both diagrams just show one set of leads going to the amp. I have a 200 watt 2 chanel amp now that might not be enough. what would be a good resonably priced amp? it is rated at 300 rms and 600 peak
Old Apr 8, 2007 | 02:54 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
wire it to 4 ohms, and bridge the amp. this is the best way to do it, that amp will work just make sure you arent clipping your gains
Old Apr 8, 2007 | 09:40 AM
robvuk's Avatar
robvuk
Your amp will deliver the same amount of power bridged into 4 ohms as it does individually into 2 ohms. You also have the advantage of a higher impedance circuit which will give a better damping factor and less speaker line loss.
Old Apr 8, 2007 | 12:42 PM
gator79's Avatar
gator79
Default wired
ok mine will be wired like this
http://www.crutchfield.com/learningc...pe=2%2DChannel
where does the second voice coil get its input from? it looks like it is just hooked up to itself. is there a conection in the speaker itself?
Old Apr 8, 2007 | 02:56 PM
robvuk's Avatar
robvuk
That is correct for 4ohm operation. The two speaker coils are now wired in SERIES as opposed to PARALLEL. Using a dc signal for example, the signal goes into one voice coil and out to the in of the other and out back to the amp.
Old Apr 8, 2007 | 02:58 PM
01QSZ06's Avatar
01QSZ06
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Good site! Tells you how to wire anything....
To subwoofer confusion
