Sponsored by: Innova
JL Stealth Box price
Old Oct 16, 2001 | 01:36 AM
vette dreams's Avatar
vette dreams
Default JL Stealth Box price
How much did everybody pay for the JL Audio Stealth box for the C-5? :D :D :D
Old Oct 16, 2001 | 11:22 AM
dtorc4's Avatar
dtorc4
Default Re: JL Stealth Box price (vette dreams)
Too much. Make it yourself, use better speakers, and save $$$. JMHO :D :cheers:
Old Oct 17, 2001 | 09:59 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: JL Stealth Box price (dtorc4)
Better speakers, than the JLW3'S?
Old Oct 17, 2001 | 11:50 AM
vader1's Avatar
vader1
Do you have any instructions on how to build it yourself? I would appreciate it because I got sticker shock pricing a stealthbox.
Old Oct 18, 2001 | 12:59 AM
Sam Lin's Avatar
Sam Lin
Default Re: JL Stealth Box price (vader1)
The Stealthbox is about $500, depending on where you go. To make one, you need decent skills with fiberglass as well as wood. Local shops who do fiberglass should be able to make one for under the $500 of the Stealthbox also.
You need to either use expanding 2-part foam or fiberglass to make a mold of the center compartment. If you use fiberglass direct, apply wax thickly to the compartment to prevent sticking.
Cut a piece of MDF to the size of the opening, with a snug fit. Cut out a speaker hole leaving about 1 inch of speaker rim clearance from the rear edge of the compartment. Go down through the hold and build up the glass with mat. Get it about 1/4 to 1/2 inch thick, layer it in the top edges/corners so it extends onto the top MDF piece, it'll then secure it.
In short, that's about all there is. I don't have time at the moment for the detailed writeup, sorry.
Sam
Old Oct 18, 2001 | 09:38 AM
JoeyG's Avatar
JoeyG
Just like Sam said except, I've found it to be just as easy to use aluminum foil to mask off and form to area. Just as good as wax paper, will hold conformed shape in area, and just peels off afterward.
If your doing it yourself you can make a completely wood enclosure the easiest way by not protruding into the lower portion of the center well. This method would be good for a single 10" or 12" speaker. Good luck.
Old Oct 18, 2001 | 09:42 AM
JoeyG's Avatar
JoeyG
HEY wait a minute. Your from Springfield! Go to Audiophile on the North Kearney(I think thats the street) in town. Ask for Geoff, If he's in tell him Joe Grier sent you, and see what he can do for you.
[Modified by JoeyG, 7:43 AM 10/18/2001]
[Modified by JoeyG, 4:45 PM 10/19/2001]
Old Oct 19, 2001 | 12:05 AM
CO_Silver_Rush's Avatar
CO_Silver_Rush
Just installed my Stealthbox and I am amazed. This thing hits like two 12s. Highly recommended. I had a CD sitting on the pass. seat and this thing bounced the CD onto the floor it was hitting so hard. Unbelievable and clean.
Old Oct 20, 2001 | 10:54 PM
dtorc4's Avatar
dtorc4
My bad...
I thought most of the stealth boxes used w0s. I own 2 10 w3s and LOVE them. :cheers:
Old Oct 26, 2001 | 12:21 PM
vette-freak's Avatar
vette-freak
check on line with extremebass.com......they might do you better than $500.
Old Oct 28, 2001 | 02:00 AM
Lashtal's Avatar
Lashtal
Are there any other products out there that are simular to this one?
I.E.: Pre-Built box with or without speakers? etc...
To JL Stealth Box price
