Sponsored by: Innova
factory stereo problem
Old Oct 16, 2001 | 06:45 PM
fmp310's Avatar
fmp310
4th Gear
Default factory stereo problem
I have a 99 C5 coupe with the factory Bose stereo and the two rear speakers are not working. The front speakers and the head unit work perfectly. I have already checked the fuse in the passanger floor board under the dash and it is fine. Please some one help me out. Thanks!
Old Oct 16, 2001 | 08:05 PM
99HT's Avatar
99HT
Default Re: factory stereo problem (fmp310)
It is either your head unit or your Bose signal processor (BSP). Without the correct equipment the only way to find the problem is to first pull the BSP and replace it with a friends. If this does not work, it is most likely the HU or a bad connector somewhere.
