Sponsored by: Innova
Parasitic drain
Old Apr 23, 2007 | 05:06 PM
chris308's Avatar
chris308
Default Parasitic drain
Hey guys,
I gotta a weird one here. Not to long ago I installed a system on my car. I was getting a ground-loop noise made a post on here but none of the suggestions fixed that (ran a better ground from HU to seat bolt where amp is grounded). Thats one issue i'll have to fix.
Now i found out the constant 12v (yellow) on the wiring harness that my HU is connected to, is draining my battery. I put a meter in series with the battery and i was getting over 1amp draw while in sleep mode. Cut the 12v constant and it drops down to .02mA.
Should i run another C-12v from another location?? Where is another C-12v circuit?? Right now i have it wired it up on a SW-12v i just don't have any memory. I can live with that for awhile.
What does it mean that the C-12v is draining my battery?
Old Apr 23, 2007 | 05:35 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I would think the drain is more a factor of the head than it is the source. Changing to a different C12v probably won't help. I'd check into the head and see if there is something you have programmed that is "staying on" and causing the drain.
Old Apr 23, 2007 | 05:58 PM
chris308's Avatar
chris308
thanks for the reply.
theres nothing really on the HU to program. I have a satellite cable connected to it. rca's and the radio antenna cable. THe only wires i was using off the OEM harness was the red (sw12v) yellow (c12v) and the blu for the power antenna.
It only draws an amp in sleep mode when i have it connected to the yellow. Maybe theres a short in the HU itself, i don't know.
Old Apr 30, 2007 | 08:33 PM
chris308's Avatar
chris308
UPDATE:
Well, I bought a new HU and wired it all back up. Turns out it was the HU causing the parasitic drain as well as my ground-loop noise!!
I'm so happy now!!
Old Apr 30, 2007 | 08:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
good news!
To Parasitic drain
