Sponsored by: Innova
Intermittent Radio Operation
Old Oct 19, 2001 | 06:12 PM
Two_Black_03's Avatar
Two_Black_03
Default Intermittent Radio Operation
To date: The radio cut out the other day and went to static. I tried a CD and that worked fine. Ergo, the antenna, right? No! As I was troubleshooting the other night, the radio started to work - the coax was not even hooked up to the receiver, so I know it isn't that. I drove to the store and it quit again. I have looked at just about everything that I can think of or glean from the manual. Anyone have any ideas?
Old Oct 19, 2001 | 09:46 PM
Dave84/76's Avatar
Dave84/76
Default Re: Intermittent Radio Operation (92_Polo_Pilot)
Sounds like the FM tuner is going bad. Next time the radio acts up, switch to AM. If you have AM, the problem is in the radio.
Old Oct 21, 2001 | 12:29 PM
white93's Avatar
white93
Default Re: Intermittent Radio Operation (Dave84/76)
Had a similar problem this past Spring, radio would cut out and come back at random. Turned out to be the receiver unit (in the back behind passenger seat in the '93). I sent it to United Radio in Syracuse and they rebuilt it for something like $75 and it works fine again. Be careful if you take it to a local shop; I took the car to one in Des Moines and they wanted to replace all 4 ampliefier/speakers at full price for. You can call United Radio and talk to one fo the folks there to get a handle on the problem.
Old Oct 21, 2001 | 01:52 PM
Dave84/76's Avatar
Dave84/76
http://www.unitedradio.com/
Old Oct 22, 2001 | 07:52 PM
Two_Black_03
Thanks for the input guys. I believe I have narrowed it to the receiver/pre-amp behind the passenger side. I tried both AM and FM, neither functions. I removed the coax from the antenna and unplugged the preamp and the thing would fade in and out. This to me seems that the antenna/preamp are not functional at all. I can hear some low signal most of the time, so I believe everything else is ok. I will call united radio and see if I can send it to them for repair (antenna just replaced).
To Intermittent Radio Operation
