Sponsored by: Innova
Final ?s before amp install...
Old May 7, 2007 | 07:27 PM
G8rDMD's Avatar
G8rDMD
National Champs Gators 4 St. Jude '09
St. Jude Donor '10-'11
Default Final ?s before amp install...
I'm getting ready to install a mono amp and sub next weekend and just have a couple of last minute questions:
1. Where exactly into the cabin does the firewall grommet behind the battery enter?
2. On the PAC-AOEM adapter, there are 2 sets of RCA cables, one labeled front, one rear. The mono amp has one set of inputs. Does it matter which set on the PAC I hook up to, front or rear?
3. Right where the RCAs enter the PAC module there are, what appear to be, level adjustment screws. Do I need to adjust these, or do all my adjustment on the amp?
Thanks for all your previous help and with your help here
Old May 7, 2007 | 08:13 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
pull the panel down under the dash on the passenger side you will see the grommet
i always hook up to the rear
generally speaking all adjustments at amp you shouldnt have to mess will the levels on pac adapter
Old May 7, 2007 | 08:20 PM
G8rDMD's Avatar
G8rDMD
Thank you.
To Final ?s before amp install...
