FS: PPI DCX 300.2 Excellent condition!!
Here are some specs on it:
4 ohm: 75x2
2 ohm: 150x2
Mono Operation: 300Wx1 @ 4 ohm
THD+N: 0.08%
S/N Ratio: >100dB
Freq. Resp.: 10Hz-50kHz
Damping Factor: >250
X/O Slope: 2-way, 30Hz-4kHz, 12dB/octave
Fan: No
QBass™: QBASS Plus/Remote
Dimensions: 13-7/8"x10-1/2"x2-3/4"
These amps are underrated and the power ratings are rated @ 12 volts unlike some other amps out there that are rated at 14 volts.
There is a reflection on the amp that makes the plexi appear broken or whatever, but it is just a reflection. The amp besides the scuffs mentioned above is in excellent shape. Here is the scuff.
