Gents, how do I know if the idiots at Best Buy gave me the correct wire harness ? This is what I got: Scosche BBGM02AB. I am putting new head unit and new speakers, all bose stuff is coming out. Before I pull the old unit out, I just want to make sure I have what I need.
also dimmer wire wont work in the harness you have to splice in at climate controls, and ignition wire wont work either you have to splice in at ignition or passenger kickpanel
Odds are, you won't even need a harness. You'll have to get switched power somewhere (passenger kick panel), a hot wire (battery), and you'll be running new speaker wire. You can ground to the metal chassis of the radio rack. The only wire I needed to pick up was the power antenna signal wire.
From what I can make out, thats it. And thanks for the info, I have read that dam faq a dozen times and each time I do, I believe that I confuse myself more and more.
I have installed many stereo systems in the past and just can not recall tackling something so confusing and so difficult as this ZO6 is turning out to be. Hopefully it is all worth it in the end. Again thanks.
