C5 double din: cutting off radio bracket?
or sawsall right down the side is the easy way
Not sure if that will work for you.. but it is just another idea.
BBent: Is yours the double din with the bezel mod like we see on here so much? Nevermind, kind of dumb question. I will just have to play with mine to see what will fit my modded bezel. I dont think it will work like you did it. I think I have to lower my ac control unit also. Guess Ill find out soon enough!
The pictures above are the bracket that sits below the AC unit.. what I did will probably work for you on that one.. but removing the top one will be harder.
Let me know how you go about getting that bad boy outa there, I gotta do the same thing, I removed all the bolts, at least i think i did to try and remove the whole cage so I could drill them out, but it didnt really want to come out, looks like theres more you gotta remove (trim,dash wise). And yeah its a 6spd.
Goodluck...
As far as the brackets go, once Greg got the dash apart he left the job to me to remove the brackets. With the cage in the car it is not fun to try and cut. So we had to get out the big guns.
Greg thought I was a little strange for attacking my car with this monster sawzall, but in a matter of minutes both brackets were out of the car.
It was then we tried to remove the cage to drill in some wholes to bold in a bracket. You might be able to angle screws into the bracket to mount to the cage, but just keep in mind that the cage itself is not that easy to drill into.
I have to give all the credit for the rest of the fitting and lining up to DPG and Pentavolvo, all I did was use the sawzall on the brackets.
Another little trick we found when Dave was putting it back together was using patches of Edead as shims since they will stick to the metal cage.
Good luck you will love the outcome and new sound. You are in good hands asking questions to DPG and Pentavolvo.
C5bears, so what did you then use for a "bracket" to hold the stereo? (I havent even opened the stereo box yet. Maybe it has a bracket or two. Its been probably 11 yrs. since Ive messed with car audio!)
So heres what I did: All done with a cordless drill, and completed with the rack mounted in the car.
#1: Took a 5/32 drill bit to start a pilot hole (any small size bit will work). I place bit on raised edge of "rivet". Holding the drill at a natural angle will put the bit at a 45 degree angle going into the "rivets". This is good cause it just right the middle of the shaft of the rivet.
#2: Go to a 5/16 drill bit and drill right into the rivet. Youll know when your done. The rack will loosen.
#3: I got a big set of 90 degree pliers (cant think of the technical name) to pry the racks back and forth until they came loose and came right off.
Finally, pull out the grinder and grind everything smooth.
I bent the 2 shelves a lil, but that just means theyll bend right back. Plus, I guess I only need one of them.
I tried to pull the cage out, got it all the way out after breaking the top brackets of the trim, then there is that one goup of wires that goes down by the e-brake and under the carpet...So i finally found a drill (neighbours) I broke about 6 of his bits....took me hours, made a mess, snapped out a few times and finally got both brackets off. Then I put the cage back in because it was a mess in there and making me even more angry. I think im done with the drill for a while.
Until the past couple of weeks, there hasn't been much info on modding the brackets, but a lot of info on modding the bezel. We were stumped as to how people were moving these things because there were no pictures or anything like that.
