Sponsored by: Innova
When using a component system......
Old May 29, 2007 | 05:39 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default When using a component system......
What do you all set your amp's crossover to? I find that the flat setting allows to much bass through making the mids sound bad. I have the Infinity 6010cs system.
Old May 29, 2007 | 06:25 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Mine is set to around 80 hz HP. Sometimes I go up to a 100hz HP.
Old May 29, 2007 | 06:37 PM
Kale's Avatar
Kale
Depends, when I ran without a sub, 60hz @ 12db.
But now that I have a sub (and run 300+ watts each side) I went with 80hz just to stay on the safe side.
You just have to play with what works right in your situation.
Old May 29, 2007 | 09:53 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
general rule of thumb, low pass sub at 80, highpass speakers at 80
Old May 30, 2007 | 07:07 PM
screw991le's Avatar
screw991le
Old Jun 21, 2007 | 03:18 PM
Patman's Avatar
Patman
How do you like those speakers? I've got the 6012i Infinity speakers, but they are just "two-ways", not a component set. Right now they are running off deck power and tomorrow I'm hooking up a Fosgate P200-2 to them and hoping they'll sound a bit cleaner (with more midbass hopefully too) But if they don't, I was considering going with the 6010cs (unless I can get a great deal on some Focals although they are pricey up here)
My sub is an Infinity Perfect 12.1 (powered by a Fosgate P500-2) so I figured it might be a good idea to stick with Infinity speakers up front just to be consistent.
Old Jun 21, 2007 | 04:34 PM
ptiller's Avatar
ptiller
I have the 6010s and they are great for the money. I am running the Infinity perfect sub too. It is a great system for the budget. I picked up the 6010s and Perfect sub off ebay for a great price.
Old Jun 21, 2007 | 04:38 PM
pentavolvo's Avatar
pentavolvo
i used to run the refence components till i heard the polk db in a buddys car and ill never go back to infinity. the polk is wayyyyy smoother sounding
Old Jun 21, 2007 | 09:48 PM
screw991le's Avatar
screw991le
After I set up the system properly, They sound awesome to me. Crisp, clear and loud highs and nice mids. I purchased them from an Ebay store for $50 shipped. I did my whole system for under $700.
I have been an Infinity fan for a long time and will probably be for a long time.
To When using a component system......
