I found 1 of the aux inputs... but I don't know what the Cor-har looks like? I have a 2000 with in dash cd (no changer) ....
The only wires I see that lead into the carpet are the ones that the needle nose pliers are pointing to...... Is that the cor har?
yes the wiring is there to the right of the fuse panel
Thanks.
I did not think I had a Cor-Har since it did not come with a cd changer from the factory? I guess all I need to hook up an aux input is this now? http://www.logjamelectronics.com/piegm10aux.html
not quite, you still need the cor-har cable if you don't have the factory changer. You can get one from gene cully. If you did have a factory changer, thats where it would be.
