Sponsored by: Innova
What Gauge Wire for Amp
Old Jun 6, 2007 | 02:02 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Default What Gauge Wire for Amp
What gauge wire should I use for a Infinity Reference 5350A 5 Channel Amp. Should I go with 4 or 8 gauge power and ground?
I'm going to mount the amp on the back wall of a 99 coupe. Being that I only see grounding wires 3-5 feet that would not be enough to go to the B piller of the seat track for a good ground. Any other suggestions were I can get a good ground within 3 feet of the back wall?
Old Jun 6, 2007 | 02:21 PM
Kale's Avatar
Kale
8 gauge will handle it, but, do 4 gauge anyway - future expansion possibility.
Old Jun 6, 2007 | 02:23 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
IMO do 4 gauge 8 will cut it close with that amp. Just run a longer ground thats what I do
Old Jun 6, 2007 | 02:26 PM
MR.WaynesWorld
So I can run a longer then 4 feet ground wire to reach the B Piller?
Any idea were I can get bulk black ground 4 gauge wire?
Old Jun 6, 2007 | 02:28 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Yes, you can run longer than 4'. Ideally the ground should be short as possible, but you can usually get away with longer.
I have used darvex.com for bulk wiring, connectors, etc.
Old Jun 6, 2007 | 02:42 PM
DPG's Avatar
DPG
St. Jude Donor '06
Thats where going with a larger gauge wire helps. You can run a longer ground with a larger gauge
Old Jun 6, 2007 | 02:47 PM
MR.WaynesWorld
Thanks Guys....
One last questions, for now at least, what gauge wire should I use from the Amp to the speakers, 12 or 16 gauge speaker wire.
Old Jun 6, 2007 | 03:02 PM
DPG's Avatar
DPG
St. Jude Donor '06
16 will be fine
Old Jun 6, 2007 | 03:05 PM
pentavolvo's Avatar
pentavolvo
16 gauge for the win
Old Jun 6, 2007 | 03:07 PM
MR.WaynesWorld
Originally Posted by DPG
16 will be fine
Thanks Dave. This will be my second major Audio mod to the wifes car. The head unit mod I did a couple of months ago looks easy compared to this one.
Hey at least it is giving me pratice before I do my Vert.
Old Jun 6, 2007 | 04:14 PM
DPG's Avatar
DPG
St. Jude Donor '06
there you go. The vettes are pretty easy to work on compared to other cars
Old Jun 7, 2007 | 02:33 PM
Fasthotrod's Avatar
Fasthotrod
I dropped a ground down the right side bin and out to the frame.
There are small ground lugs back there, one on either side up on the frame next to the mufflers. If I had my camera, I'd take a snapshot and post it for ya.
Mark
Old Jun 7, 2007 | 02:37 PM
MR.WaynesWorld
Mark
Thanks Mark. When I get ready to install the amp I'll be sure to look on the under side for a grounding point. I take it you had to drill a hole for the ground wire to get it there.
To What Gauge Wire for Amp
