Sponsored by: Innova
Audio Cut Out--help
Old Jun 12, 2007 | 12:43 AM
A.Fry's Avatar
A.Fry
Default Audio Cut Out--help
ive got a clarion vrx735vd, its been installed for about 4 months and working fine. all the sudden it started loosing the audio, it will play about 3 min. and sometimes maybe 30 min. and just go off. sometimes i can turn it off and back on and it will come back on for a short while and go back off again. the power stays on the display but just the audio goes off. ive beat on it, checked the grounds and all the sens. settings and it will not stop. any suggestions? thanks anthony
Old Jun 12, 2007 | 12:58 PM
TOOGECKO's Avatar
TOOGECKO
Sounds like a loose connection. I had a similar incident a few months back after about two months of my install. Turns out that one of the pins in the HU harness was loose and causing in my case, the power lead to short. Check the obvious connections to your amp first; if all else fails you may have to check the wiring behind the headunit...
Old Jun 13, 2007 | 04:12 PM
A.Fry's Avatar
A.Fry
thats exactly what it was. thanks for the advise
To Audio Cut Out--help
