Sponsored by: Innova
C6 JL Stealthbox opinions
Old Jun 19, 2007 | 03:47 PM
tejasvette's Avatar
tejasvette
Default C6 JL Stealthbox opinions
Looking to hear from those that have the stealthbox installed in their C6 or have heard one. Do they sound good?
Old Jun 19, 2007 | 08:11 PM
Dodzilla's Avatar
Dodzilla
I like mine just fine. Certainly not the most impressive sub setup but it looks good, allows for storage of the top and provides enough bass to satisfy me. It's a little pricey for what you get (it's just a 10w3 in a sealed enclosure) but the quality is pretty good. You can always swap out the JL driver for something a little more serious too.
My only complaint is that I've got a few rattles in the hatch area at certain frequencies so I'm gonna tear apart the car this weekend to install some additional deadening/insulation. That's an issue with the car and not the enclosure though.
Old Jun 21, 2007 | 12:55 AM
Brabus2's Avatar
Brabus2
Thanks for sharing that info, I'm also in the fence whether I should pull the trigger on the JL box or go custom.
Old Jun 21, 2007 | 01:13 AM
onebadramair's Avatar
onebadramair
wow, i was just searching for this...
from just the few posts It sounds like its a clean setup but not impressive by any means whn performance is questioned.
I'm glad I didnt order this afternoon....and the search carries on
Old Jun 25, 2007 | 11:38 PM
Gabel1's Avatar
Gabel1
Audio Dave makes an excellent custom C6 box for less than JL No rattles, & the top stows away with no problem. Pic:
Last edited by ERND IT; Dec 21, 2007 at 08:07 AM. Reason: non vendor posts not allowed
Old Jun 25, 2007 | 11:46 PM
thatdood's Avatar
thatdood
I like the look but I dont see how its much cheaper than the stealthbox after you add the subwoofer. Plus the sub has to be 5 inches or less for the mounting depth. The JL 10W3 won't even fit it.
Old Jun 26, 2007 | 12:54 AM
ShockwaveGT's Avatar
ShockwaveGT
Yes, the JL Steathbox is expensive, but trust me, it's worth EVERY penny.
I ran a JL 250/1 amp to power the Stealthbox and everyone thought I had a lot more in the back than just a 10in sub and 250watt amp. It truly sounds quite impressive. The bass is DEEP, and sounds amazing, even with the factory headunit and factory speakers. In fact the rest of the speakers sound better because you can take some of the low end load off of them.
What the JL box does that really makes it worthwhile has to do with it's design and construction. It essentially turns your entire interior cabin into an enclosure and everything just sounds so good. There isn't any distortion or rattling either. JL did their homework to ensure a perfect fit with optimal results.
Sure you can get a cheaper solution, but I don't think you'll end up with the same quality results.
If you are on the fence, and you can afford it, jump over that fence and don't second guess it. As soon as you hear it, you'll be glad!
I still have to reinstall it in my VY C6, as I got rid of my black one. It's killing me how weak the factory system is without a good sub!
Old Jun 26, 2007 | 09:49 AM
David Garren's Avatar
David Garren
I used Audio Dave's with a dual coil shallow Pioneer sub.
Old Jun 26, 2007 | 11:11 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Well, other than the fact the carpet color looks much better on Daves, if his is 320.00 plus a good sub for 150.00 or so, thats about 470.00 vs 650.00
How is this not much cheaper???
P.S.
I don't have either...
Old Jun 26, 2007 | 11:14 AM
thatdood's Avatar
thatdood
P.S.
I dont ever buy anything at full retail so I would expect to get the Stealthbox closer to $50 - $100 off. If I could get the same JL sub in the enclosure its a pretty good deal but I cant due the mounting depth restrictions.
Old Jun 26, 2007 | 11:21 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
It's been generally talked about that the JL woofer that is used is fairly lowend.
Sorry, but I still don't see an answer here...
I have been quoted 599.00 as well but it's still not 470.00 and there are plenty of good woof's that are shallow these days...
A lot in the 3.0 to 3.5 range...
Old Jun 26, 2007 | 12:48 PM
thatdood's Avatar
thatdood
My problem is that I've only used JL audio subs my whole life (well once I used Polk MoMo subs and they sucked). Your probably right and I need to give a few other brands a chance.
Old Jun 26, 2007 | 02:47 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
I use the JL in my Avalanche, (another stealth) and it does sound good, my only real issue with it is the apparent "Vette tax", the same configuration is usually much less for cars like the 350Z, S2000, etc...
Old Jun 27, 2007 | 08:28 AM
thatdood's Avatar
thatdood
I stopped by the local car toys and was told the stealthbox was $799
Talk about Vette tax. Called another place and was told I could get it for $550
Old Jun 27, 2007 | 08:58 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Retail (for what thats worth) is 650...
Old Jun 27, 2007 | 09:39 AM
thatdood's Avatar
thatdood
I knew he was trying rip me off. Needless to say he lost out on over 3K worth of business for trying to scrape off an extra $150 bucks.
Old Dec 16, 2007 | 09:15 PM
jrhunkler's Avatar
jrhunkler
Default David Garren: Q?
HOW DO YOU LIKE THE PIONEER SHALLOW SUB? MY YOUNGER BROTHER SWEARS BY THEM... ITS ALL HE USES IN HIS CUSTOM INSTALLS HE DOES FOR HIS FRIENDS... I must say, his own stereo in his Nissan Tiatn sounds incredible, and he thinks Im OUT OF MY MIND... for looking into Focal and JL Audio 10" Stealthbox's lol
To C6 JL Stealthbox opinions
Old Dec 19, 2007 | 11:09 PM
tilithz's Avatar
tilithz
Last edited by ERND IT; Dec 20, 2007 at 08:23 AM. Reason: NON-VENDOR POSTS NOT ALLOWED
Old Dec 21, 2007 | 03:01 AM
tilithz's Avatar
tilithz
post about jl audio is not allowed cuz they aren't a supporting vendor???!!! geez... what is happening here??
Old Dec 21, 2007 | 08:28 AM
ERND IT's Avatar
ERND IT
CI-3 Car Show Winner
CI-4 Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '06-'09
Actually, the references to the JL Audio brand are fine. Sorry, but posts promoting non-forum vendors are prohibited... here are the commercial posting guidelines:
http://forums.corvetteforum.com/show....php?t=1118158
