Sponsored by: Innova
C5 Avic-D3 FM Reception Problem. Help!
Old Jun 25, 2007 | 12:22 PM
cletus's Avatar
cletus
Default C5 Avic-D3 FM Reception Problem. Help!
Although I don't use it much, the FM reception from my new Avic D3 is really weak; lots of static where the stock Bose was crisp and clear. What gives? Pioneer phone support said the antenna amp is off or something. Can someone help me figure this out?
Please.
Old Jun 25, 2007 | 12:27 PM
DPG's Avatar
DPG
St. Jude Donor '06
only the coupes have the amplified antenna if I remember right. Check the connection behind the HU for the antenna
Old Jun 25, 2007 | 12:33 PM
cletus's Avatar
cletus
I have an '01 Vert. Thanks.
Old Jun 25, 2007 | 12:52 PM
DPG's Avatar
DPG
St. Jude Donor '06
yea i saw that in your profile. Check your connection in the back to see if something might have gotten pinched or something else.
Old Jun 25, 2007 | 08:57 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Stupid question, did you use the GM antenna adapter so the size matches up?
Old Jun 25, 2007 | 09:05 PM
cletus's Avatar
cletus
Yea, I wish it was that easy, but the adaptor was used and everything seemed snug and not bent or anything...
Old Jun 26, 2007 | 09:26 AM
DPG's Avatar
DPG
St. Jude Donor '06
i know this sounds stupid too, but unplug everything and reconnect it all. I've had instances where the connection seems snug or good, but then I'll just redo it and then it works. Worth a shot.
If that still doesn't work, make a call to pioneer and explain to them that the vert doesn't have an amp for the antenna and see what they suggest after that. Do you get static/ bad reception with the car on or off, or doesn't matter?
Old Jun 26, 2007 | 09:38 AM
cletus's Avatar
cletus
The car's running doesn't seem to make a difference. And on some really strong stations when you're in just the right spot the reception is normal, but mostly it's unlistenable...
I guess I'll break it all down and try the unplug and replug idea. Ugh!
Old Jul 2, 2007 | 08:22 PM
mperl93's Avatar
mperl93
Same problem here with an Alpine stereo. Connection is fine, I already tried that approach. The stock stereo got much better reception. Maybe the power antenna's just suck for reception with after market stereo's.
If you found a way to make it work better let me know.
Old Jul 5, 2007 | 04:24 PM
Jimmy 2 Times's Avatar
Jimmy 2 Times
one thing that I have noticed when doing installs, is that radios, or other devices that use antenna adatpers pick up noise. My solution, make sure to route the antenna wire away from the power harnes, and use good electrical tape and tape off all connection points.
give it a try and report back
Jimmy 2 Times
oh, and did I mention, I am a MECP first class installer
Old Jul 5, 2007 | 04:43 PM
cletus's Avatar
cletus
Thanks. I'll try that. I'm going to open it up this weekend or so.
To C5 Avic-D3 FM Reception Problem. Help!
