New adapter lead in U.K.
In U.K. all aftermarket H.U. are ISO connection.
This lead is ISO on one end and C5 on the other.
I will pull the dash tomorrow, and loosly fit my aftermarket H.U. and see if it works
I have 2004 without CD changer.
there is no switched ignition power there, while the wire is in the harness its gonna be dead so you have to run a wire from the passenger footwell or ignition switched to get a switched wire for your radio, also bose subs will no longer work
I pulled the H.U. out and took one look at the Rear connections, and that is as far as I went.
Oh well, back to the shop for a refund.
Nothing lost.
Looks like I will go for the ipod route.
I have looked at the vast array of cables and splitters, and to be honest, I am quite confused now.
I thought I had it all sorted in my head what to buy, now I guess it ain't so plain anymore.
Suggestions, everyone please, cables ?
I want to keep the stock H.U. and I will use ipod( or similar)
I don't have c.d. changer in the trunk, just the amp.
THANKS
