Sponsored by: Innova
8" woofers in doors
Old Jul 8, 2007 | 01:06 PM
boardroomjimmy's Avatar
boardroomjimmy
Default 8" woofers in doors
Has anyone built a system using a 8" woofer in the door to cover mid-bass and sub duties. I really don't want to deal with a sub in the rear of my c6. I always seem to have sub box regret sooner or later in my installs. I was thinking a "musical" 8" like jl might be a good compromise. Diamond makes a 3.5 with a dome tweet to handle the upper range. If I crossed over the 8 @ 1000hz ya think it would sound ok. I know I won't have big base out of the 8's but with a quality speaker and enough amp I think it would work.
Old Jul 8, 2007 | 01:09 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
8" in the doors can be done, however you'll have to find a different spot to mount the mids and tweets otherwise you'll just be firing into the door panel. Englandgreen used 8" Rockfords in his doors.
Old Jul 8, 2007 | 01:36 PM
boardroomjimmy
I'd put the diamond 3.5 in the stock loc. they're a co-ax. Could I fit a 4" in the stock loc? Focal makes 4" only and would like the best quality possible.
Old Jul 8, 2007 | 03:19 PM
scott_fx's Avatar
scott_fx
he has a c6
Old Jul 8, 2007 | 05:39 PM
fej's Avatar
fej
Yes you can run 8's ... you either need a low fs large format tweet (think home audio) to pair it with, run some sort of 3 way setup with a dedicated midrange and tweet, or use a 3" or so widerange (check out partsexpress).
If you plan on running subless .. spend the time to properly deaden your doors and de-couple the drivers ... I personally am very happy with the product from Rick at Raamaudio, especially the ensolite.
G'luck
Fej
Old Jul 8, 2007 | 06:52 PM
boardroomjimmy
I planned on deadening the doors up good, I think the right 8" should give a good punch. But can I fit a focal 100cv in the stock 3.5 loc? they're 2.25" deep and 122mm across (4in). I then could use a 5.25 matching cv in the rear for fill.
Old Jul 8, 2007 | 07:15 PM
boardroomjimmy
Ok, answering my own questions today.. look up focal 210 cv1 @ woofersetc.com. 8" with tweeter 160 watt capacity. May be viable option for others that don't want sub box and can live without big thumpers. I think I'd still use a quality 3.5 up top for better imageing though.
Old Jul 8, 2007 | 09:52 PM
scott_fx's Avatar
scott_fx
how about using a peerless or seas 8" and matching it with a Hiquphon OW1, Peerless 810921 or North D2506-S and match it with am 8"
I bet even a 7" in a well deadened door would hit pretty low
Old Jul 8, 2007 | 11:13 PM
VinceC5's Avatar
VinceC5
I deadened my doors with dynamat xtreme. Running 8" kickers for now with 4" midrange and 1" tweeters. Sounds real good. I've removed my 12" sub and still like the way it sounds.
Old Jul 8, 2007 | 11:45 PM
scott_fx's Avatar
scott_fx
I was suggesting a two way because it'll be easier to tune, 3 way will work great too though
Old Jul 9, 2007 | 12:30 AM
Spkrboy's Avatar
Spkrboy
I'll suggest something a little different than the others.
Since you'll be trying to reproduce low frequencies with a driver that will also be handling some significant portion of the midrange, there will be some problems with intermodulation distortion. It's a bit different than using a 3-way component set with a subwoofer.
The solution I think works best in this setup is to use a very high quality 2-way component set (custom or otherwise) with a small midrange (3.5-4"). Put the mid in the door, and play with the tweeter location for imaging (talk to Fej ) Use an active crossover with steep slopes (24dB/octave) and set the crossover point somewhere between 185-300. This way you'll avoid most of the distortion issues. It also keeps you from having to find an 8" midbass that's capable of high-quality reproduction up to 1 kHz (short list). This idea would require exceptional components, but allows some flexibility in the midbass choice. The low-fs tweeter isn't necessary in my proposal, but still could work if you chose that route.
Old Jul 9, 2007 | 11:11 PM
boardroomjimmy
Where are the peerless or seas you talk about available? I think one of them produce the 6.5" in my alpine x's, and I beat the hell outta them.
Old Jul 10, 2007 | 02:09 AM
scott_fx's Avatar
scott_fx
www.madisound.com and www.solen.ca are the two places I get my speakers from
Old Jul 10, 2007 | 09:11 AM
Spkrboy's Avatar
Spkrboy
Other reputable stores:
http://www.speakercity.com
http://www.zalytron.com/
http://www.orcadesign.com/
http://www.e-speakers.com/
http://www.meniscusaudio.com/
Old Jul 10, 2007 | 05:03 PM
Steve Germany's Avatar
Steve Germany
Don't forget www.partsexpress.com - they ship to APOs!!!
Old Jul 10, 2007 | 05:19 PM
leolufse's Avatar
leolufse
How about forum members?
I've got a set of DSL 8" components with c6 mounting plates for sale. Look here:
http://forums.corvetteforum.com/show....php?t=1752923
Old Jul 10, 2007 | 11:05 PM
boardroomjimmy
Thanks for all the info. If I recall correctly vifa supplies speakers to more than one car stereo brand. Found a 4ohm 8" that would probably work nice. Thanks.
To 8" woofers in doors
Old Jul 10, 2007 | 11:20 PM
scott_fx's Avatar
scott_fx
dont be overly concerned with getting a 4 ohm over an 8 ohm.
Old Jul 10, 2007 | 11:27 PM
Spkrboy's Avatar
Spkrboy
Would that be the PL22WR09/04 ?
Old Jul 11, 2007 | 01:09 AM
scott_fx's Avatar
scott_fx
a little more info on my comment:
http://www.diymobileaudio.com/forum/showthread.php?t=31
