Sponsored by: Innova
Crazy Cowboy kit>>>
Old Jul 23, 2007 | 05:08 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Crazy Cowboy kit>>>
Is it worth it?
I need to gut the interior of my new(er) C4 and clean it. i figured this would be a good time to install that kit.
I don't plan on deadener at the moment as my 89 only has it in the hatch area. from reading on Crazy Cowboy's website it seems like a good thing.. any feedback on before or after from people that installed it??
Old Jul 23, 2007 | 06:26 PM
Darion's Avatar
Darion
I installed this kit, along with deadener, in my C5 and thought the kit was worth it. Now, I can't tell how much difference it made from a sound perspective, Dynamat went in at the same time, but from a heat pespective it worked well. Since the exhaust runs down the middle of the car it would get pretty warm and heat up the inside cabin temp. The kit has reduced the heat coming into the cabin so looking at it in that way alone it was worth it. If you get the precut kit you will do alot of fitting and trimming, it is more like a starting point to get you started not a perfect fit.
Hope that helps,
Darion
Old Jul 23, 2007 | 06:46 PM
DPG's Avatar
DPG
St. Jude Donor '06
have only heard good things about the kit
Old Jul 23, 2007 | 07:54 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Put one in my Wifes Coupe and it helped a lot on the noise and heat... Got one for my Vert which I'll do over the winter.
Old Jul 23, 2007 | 08:30 PM
thatdood's Avatar
thatdood
I've got the kit coming this week for the entire car and dynamat for the doors and rear of the car as well.
I'll let you if it was worth it or not.
Old Jul 24, 2007 | 01:02 AM
-=Jeff=-'s Avatar
-=Jeff=-
Thanks Guys,
I PM'ed Crazy Cowboy. i am going to order a kit.
Old Jul 24, 2007 | 10:00 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I combined the Crazy Cowboy with some Thermo King. Made two long trips (NC and KY) and can tell you there were no heat issues at all.
If you do both like me, put the Crazy Cowboy down first and top it with the Thermo King.
Old Jul 24, 2007 | 11:30 AM
fej's Avatar
fej
I was happy with the cowboy kit, certainly cut heat down, and some sound as well. Mine went down on top of the edead liquid deadener. If I had it to do all over again I would try and split a cowboy's kit with someone for the tunnel heat reduction and couple it with ensolite from raamaudio for sound deadening purposes everywhere else.
Good product and coupled with some mat should work very well .. just be careful at certain mounting locations that your interior will go back together correctly, you don't want to do all of that work and then be too thick under the carpet to snap back together
Fej
To Crazy Cowboy kit>>>
