Sponsored by: Innova
Help
Old Jul 23, 2007 | 09:49 PM
old guy with vette's Avatar
old guy with vette
Default Help
I am installing a Pioneer system in a 91 convt, can't locate the feed for the antenna. I've looked at a bundle of wires in the compartment behind the pass seat, can't locate a pink one. Any help locating it would be appreciated.
Old Jul 23, 2007 | 10:20 PM
-=Jeff=-'s Avatar
-=Jeff=-
passenger side under the dash.. that is where the antenna will be.. the tuner module in 90-93? (for sure 91) is there
Old Jul 23, 2007 | 10:32 PM
old guy with vette
I found the antenna lead. Sorry I wasn't clear. I can't seem to locate the wire that connects to operate the antenna when the radio is turned on.
Old Jul 23, 2007 | 10:34 PM
-=Jeff=-'s Avatar
-=Jeff=-
Should be int he same area off of the tuner.. I forget which wire though
Old Jul 23, 2007 | 10:44 PM
old guy with vette
Jeff, I went back and read the FAQ's and I know where to look, the receiver has plugs that contain all the wires. Will try there although the plugs are difficult to reach. Thanks for your help.
Old Jul 25, 2007 | 02:09 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
It is the plug on the right side of the CDM. One wire is power, one ant, one lights?
To Help
