I have a '99 C5 with a factory CD changer in the main cargo well that I relocated to the well on the far right. The changer had 4 screws holding it to the back wall of the car, and the heads are on the outside of the car, which I can not get to. So I can not remove these 4 screws. Ordinarily I wouldn't care, but these 4 screws are preventing my stealth box from sitting flush in the cargo well.
Does anyone know how I can remove these 4 screws? Or do I have to cut them out?
If you can't get at them from the outside of the car (the best way, no matter how much aggravation), then use a dremel-type tool to cut off the portion inside the car, then seal the ends with something like an undercoating spray.
