Sponsored by: Innova
it likes green colored CD-Rs
Old Nov 4, 2001 | 04:24 PM
J Z06's Avatar
J Z06
Default it likes green colored CD-Rs
My Clarion CD Changer in my '90 seems to like to play standard CD's or Sony Green Colored CD-R's. Anything else...it takes forever to read it,and or it'll ignore it.
This problem has been around a while.Also,ONLY with the CD Changer on, the right side speakers are off .Sometimes the CD will cut out a bit. ONLY with the Changer on(It happens with burned or reg CD's)tape player and head unit are fine.I wasn't sure if I should address it seeing I am selling the car..but I guess I am going to fix it seeing I probably have another month before the snow hits and it goes night night.
The system is all Clarion. ARX 7370 Head unit,Changer, Clarion Speakers, Small Amp. Not a bad little system.
Any ideas if it needs a professional cleaning(I tried a CD Cleaning disc) Suggestions?????
Thanks....... I remember a nice dood....triple black? answering my question last time...maybe you could offer your .02?
Appreciate it...........JD
[Modified by JD 90 383, 3:26 PM 11/4/2001]
Old Nov 5, 2001 | 01:25 PM
J Z06's Avatar
J Z06
Default Re: it likes green colored CD-Rs (JD 90 383)
Old Nov 8, 2001 | 02:39 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Try burning the CD's on a lower speed. Often, when you increase the speed, the write quality diminishes.
MS
Old Nov 13, 2001 | 07:33 PM
J Z06's Avatar
J Z06
Default Re: it likes green colored CD-Rs (DocSandy)
I always burn at 2x. It seems to like sony green cd-r's.
Old Nov 14, 2001 | 12:32 AM
Speed-Racer's Avatar
Speed-Racer
That could also be the fault of the recorder. *if* the laser is slightly off calibration, then it may not work in all units. I found this the case with my old Hp CR writer. The newer model seems to work in everything, but also the color reflectivity and lasar beam dampening plays a role too.
Speed-Racer
Old Nov 28, 2001 | 07:47 PM
J Z06's Avatar
J Z06
Default Re: it likes green colored CD-Rs (Speed-Racer)
I'm hoping it can be repaired.. I'm having it pulled and examined soon. I'm thinking the laser might need cleaning or replacement. The car was painted last year...and a LOT of body dust got in the back. Maybe thats it. I can't stand it anymore though! Time to take action.
JD
To it likes green colored CD-Rs
