Sponsored by: Innova
Componet set with good low end extension?
Old Aug 12, 2007 | 12:35 AM
andrewjhaley's Avatar
andrewjhaley
Default Componet set with good low end extension?
Open to recomendations for door mounted componet set with good low and mid extension
Old Aug 12, 2007 | 12:50 AM
Kale's Avatar
Kale
I run my Dynaudio 8" component set with no high pass filter.
They get fairly low. Size and excursion will be your friend here.
Old Aug 12, 2007 | 05:25 AM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
agreed, a buddy (nyc vette) has NO subs in his car and bass with focal polykevlar 4 inch component set and 8 inch focal woofers in his doors. My car with the same 4 inch component set and the 6.5 midbass extension to match has less low end in the doors by a HUGE margin. and I have probably 3x's the deadening he has in his doors. Go large (8 inch with a spacer) if you want low end in the doors.
Old Aug 12, 2007 | 09:44 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
if you don't have a specific make/model prefernace, a good way to tell a speaker's excursion is looking at the magnet size and the width/construction of the surround. Speakers with large magnets and surrounds were designed to have a better low end "kick" and do very well when mated with a deticated midrange and tweeter.
Some speakers like my alpine SPX 177r comps have surrounds that have folds in them allowing for tight powerful low end without sacrificing midrange. They provide excellent bump for 6.5"s
Old Aug 12, 2007 | 12:25 PM
Kale's Avatar
Kale
keep in mind though, some companies put huge magnets and surrounds on for the bling factor.
Old Aug 12, 2007 | 01:04 PM
DPG's Avatar
DPG
St. Jude Donor '06
Old Aug 13, 2007 | 01:14 PM
leolufse's Avatar
leolufse
If you want total steath try a set of JL6w0 subs with a 4" component set in the doors. I did this in a friend's install and it was pretty impressive. If you are a huge audiophile, you may not like the transition between the 6" sub and 4" comp, but the majority of folks will not notice the dip.
To Componet set with good low end extension?
