Sponsored by: Innova
Help on Avic Z2 install
Old Aug 25, 2007 | 02:01 PM
MaddSkillz's Avatar
MaddSkillz
Cruising
Default Help on Avic Z2 install
At the moment, am installing the AVIC Z2 into my C6 with onstar. I have the GMAHCM as well as the GMAH24B and am running into a slight problem. The GMAHCM says to connect the yellow to the GMAH24B's yellow. On the Z2 harness there is a yellow wire labeled battery with a 10A fuse connected to it. Where does that get connected to if already the GMAH24B's yellow is connected?
Old Aug 26, 2007 | 04:06 PM
askiles's Avatar
askiles
You have to tap into that same yellow wire. It is constant power, and that is what the chime module needs.
-Andy
Old Aug 26, 2007 | 11:15 PM
USAF_C6's Avatar
USAF_C6
To Help on Avic Z2 install
